I have the replacement part 'Water-Actuator'. But I don’t have the specs to perform the installation. This is the pedal that is pushed to distribute water into a drinking glass. I'm not sure if the frame that surrounds the water and ice pedals just pops off to access were it needs to be installed?
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
