This is a Sharp microwave but it would not allow me to list it as such under "BRAND".? I have power to the touch pad, the interior light, and timer function properly. No noise of operation at all. No fan, no turn table, no heat. Work is slow and I really need to fix this myself if possible. Thank you for your time, Matt Doyle
The door switches can cause this use this link for detailed instructions on how to check the door switches. I think it would have to be the primary switch but this depends on how its wired and I do not work on sharp often so not sure. Microwave Repair Guide
Thank you very much for your time applianceman! I will give that a try. Great link too! Matt Doyle
