mdoyle
#1 Posted : Sunday, May 3, 2009 7:32:42 PM(UTC)
mdoyle
This is a Sharp microwave but it would not allow me to list it as such under "BRAND".? I have power to the touch pad, the interior light, and timer function properly. No noise of operation at all. No fan, no turn table, no heat. Work is slow and I really need to fix this myself if possible.
Thank you for your time,
Matt Doyle
applianceman
#2 Posted : Monday, May 4, 2009 6:09:33 PM(UTC)
applianceman
The door switches can cause this use this link for detailed instructions on how to check the door switches. I think it would have to be the primary switch but this depends on how its wired and I do not work on sharp often so not sure. Microwave Repair Guide
mdoyle
#3 Posted : Tuesday, May 5, 2009 7:05:11 PM(UTC)
mdoyle
Thank you very much for your time applianceman! I will give that a try. Great link too!
Matt Doyle
