Kenmore refg. model # 106.56544400 Ice maker problem. This model has water and ice in the door. Water works fine but no water is going to the ice maker. What do I need to replace? entire ice maker? pump? but it works to the water. Thanks Randy rwm64409@yahoo.com
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear and not frozen in the fill tube.
