You will need a meter to check things.
Originally Posted by: Philibi4  Dryer will not heat The first thing I would do is flip the dryer breaker off and on a few times, to be sure that the breaker is not partially tripped. Just because the dryer runs dos not mean that you have all the power. After that you would have to take the back off of the dryer, and check the element, and the thermal fuse, which is located on the heater housing up on the left side. Usually it is one or the other. Tom www.applianceeducator.com:cool:
