Had a repair person come and he diagnosed a control board problem. Wanted more than my budget could afford-close to $500. I ordered the part-installed it and everything worked great-ice was popping out-freezer was cold and so was the fridge. Woke up this morning and back to square one-water all over the floor and both sides no longer cooling. I suspect when it went to the defrost cycle it did not come back on. What now?
If nothing running, the new control board probably blew out, possibly by a shorted compressor. If the fans are running, but not the compressor, you will still need to check the compressor for a short. You will need a meter to do that.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I set my refrigerator temp.down and nothing changes,it runs 40
