J1m
#1 Posted : Thursday, April 30, 2009 6:23:18 AM(UTC)
J1m
I am working on a Maytag Washing Machine that makes a loud roaring sound when it goes into the spin cycle-so loud you don't want to be in the same room with it.
I have removed the wash tub and the plastic nut on the spin cycle shaft but below the nut is a 4 bolt flange that I need to remove. It is aluminum and I have been to the web site and the on line help but can not tell if it is threaded or or if I need to use a puller on it.
J
#2 Posted : Thursday, April 30, 2009 2:46:25 PM(UTC)
Hopefully the Service manual will help. Possible you'll need some special tools.
Here are the breakdown diagrams and Replacement parts for MAYTAG PAV2200AWW | AppliancePartsPros.com
P.S. Check how freely the pump pulley is moving. It can be noisy too.
J1m
#3 Posted : Sunday, May 3, 2009 7:59:30 AM(UTC)
J1m
Hi Gene-thanks for the link to the repair manual--that is just the bit of info I needed.
J
J1m
#4 Posted : Monday, May 4, 2009 9:19:40 AM(UTC)
J1m
As it turns out-the spin hub is threaded and the hub may require a bit of coaxing with a rubber mallet and a large wrench. I also had to clamp the agitator shaft to keep it from turning while I rapped on the hub wrench.
Once I had it unscrewed and the tub removed I found that the hub seal had deteriorated and water had rusted the spin bearing--lots of noise. A new part from this site and all fixed.
Thanks for the help Gene.
#5 Posted : Monday, May 4, 2009 9:06:48 PM(UTC)
You are welcome. I'm glad you were able to fix it.
