i check outlet, start button, door switch, temp fuse and still not working
A model number may be a big help. A wiring diagram may be avaailable on the net. Model Number LocatorHow did you check the outlet? Did you check for the correct power at the terminal strip in the unit? |
THIS FORUM IS DEAD!!!!!!! |
