My Admiral Dryer LNC7753A71 suddenly stopped working. No power, no light, no sounds. House power is good. Power cord is good. Door switch and thermal switches have continuity.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
With a multimeter set to voltage check to see if there is 240v at the terminal block.
Thanks for responding. Yes, I have 240v at the terminal block.
