Todd7724
#1 Posted : 14 years ago
Todd7724
My cloths are still damp at end of cycles and dry not getting as hot as usual. What parts do I need to replace.
#2 Posted : 14 years ago
Replacement parts for WHIRLPOOL WED8300SW1 27" Electric Dryer | AppliancePartsPros.com
Often this is venting problems.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
