My cloths are still damp at end of cycles and dry not getting as hot as usual. What parts do I need to replace.
Here are your parts Replacement parts for WHIRLPOOL WED8300SW1 27" Electric Dryer | AppliancePartsPros.comOften this is venting problems. Unplug the unit and disconnect it from the vent system. Now try a run. If it now dries OK odds are the vent system needs checking/cleaning. Be sure to check that the louvers on the outside of the house open correctly. If you do not want any lint in the house. Take a pair of pantyhose. Put one leg into the other and then attach this to the dryer's vent. Leave enough room so the pantyhose can balloon out like a windsock. Both the above will let you check the temperature and the air flow. |
THIS FORUM IS DEAD!!!!!!! |
