I removed the sump assembly and motor to clean out the food chopper screens that were nearly totally clogged and not cannot figure out how to remount the gasket and sump assembly with motor (which is disconnected from the sump assembly at this time).
Usually, I can figure out how things are reassembled, but in this case, even looking at exploded views of the entire assembly I have no clue as to how to put the sump assembly and gasket back on the bottom and secure it.
Advice very much appreciated -- thanks.
MikeSp
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  EXACTLY what I needed -- took 15 minutes to reassemble everything and have it running like new!!! :) :) :) Thank you, thank you, thank you!!! MikeS
