MikeSp
#1 Posted : Sunday, April 26, 2009 11:19:34 AM(UTC)
MikeSp
I removed the sump assembly and motor to clean out the food chopper screens that were nearly totally clogged and not cannot figure out how to remount the gasket and sump assembly with motor (which is disconnected from the sump assembly at this time).
Usually, I can figure out how things are reassembled, but in this case, even looking at exploded views of the entire assembly I have no clue as to how to put the sump assembly and gasket back on the bottom and secure it.
Advice very much appreciated -- thanks.
MikeSp
#2 Posted : Sunday, April 26, 2009 12:17:34 PM(UTC)
MikeSp
#3 Posted : Sunday, April 26, 2009 1:43:49 PM(UTC)
MikeSp
Originally Posted by: denman Go to Quoted Post
EXACTLY what I needed -- took 15 minutes to reassemble everything and have it running like new!!! :) :) :)
Thank you, thank you, thank you!!!
MikeS
