Thanks upfront. History. Purchased between 2003 or 2004. Moved to NC and it was stored in the basement for over two years. Finally installed it for use at our small B&B and has always had an imbalance issue, but usable. The unit has sat now unused for about a year. Just tried to wash and am getting error code d5. There appears to be a broken button/micro switch above the door lock which I can activate by pushing in manually. I do not remember if this used to extend out but appears to be the case. How do I remove the front panel or front cover to replace the door switch? I have worked on many appliances/mechanical devices through the years but this one is not obvious. All suggestions are greatly appreciated.
I cannot find any info on the given model number. Please check it. |
THIS FORUM IS DEAD!!!!!!! |
Mod# - Mah8700aww Ser# - 10299392ge
