mountainh
#1 Posted : Monday, October 3, 2011 6:27:37 AM(UTC)
mountainh
Thanks upfront.
History.
Purchased between 2003 or 2004.
Moved to NC and it was stored in the basement for over two years.
Finally installed it for use at our small B&B and has always had an imbalance issue, but usable.
The unit has sat now unused for about a year.
Just tried to wash and am getting error code d5. There appears to be a broken button/micro switch above the door lock which I can activate by pushing in manually. I do not remember if this used to extend out but appears to be the case.
How do I remove the front panel or front cover to replace the door switch?
I have worked on many appliances/mechanical devices through the years but this one is not obvious.
All suggestions are greatly appreciated.
#2 Posted : Monday, October 3, 2011 7:52:32 AM(UTC)
I cannot find any info on the given model number.
Please check it.
mountainh
#3 Posted : Monday, October 3, 2011 9:32:08 AM(UTC)
mountainh
Mah8700aww
10299392ge
mountainh
#4 Posted : Monday, October 3, 2011 9:35:32 AM(UTC)
mountainh
Mod# - Mah8700aww
Ser# - 10299392ge
