gsjon
#1 Posted : Saturday, April 25, 2009 4:48:37 PM(UTC)
gsjon
Freezer coils freeze up. I replaced the defrost heater but it still does the same thing. The coil fins get iced up from te bottom to about 1 3rd of the way up.
woodchuckie
#2 Posted : Saturday, April 25, 2009 7:33:41 PM(UTC)
woodchuckie
The full length of the evaporator should be frosting up. The defrost system then melts the frost and it starts all over. The partial frost pattern you describe is a classic sign of a system low on freon.
gsjon
#3 Posted : Sunday, April 26, 2009 5:42:13 PM(UTC)
gsjon
If unit is low on freon will that also make it stop freezing. It will freeze ok for a day or two then the ice in the ice maker starts to melt and the food starts to thaw out.
