Machine will operate beginning at the 15min cycle, but will shift to a slower agitation during the last 6min cylce, then stop. Timer continues to count down to drain/spin cycle.
Found the motor to be very hot, spin cycle initiates, water pump drains fine, but there is a lot of clunking, sometimes it seems like it slips out of gear, then goes back again, if I'm lucky it will speed up to spin when the motor is cool, but it seems to go into thermal protection mode.
I pulled the motor, not very serviceable, but it spins fine, bearings seem ok. No visual overheating, just very hot and electrical smell from overheating.
My question is, could it be the transmission/brake causing the motor to overheat? There is some reddish oxide/crusties at the shaft to basket area. No wet water at this time, but there is some nasty residue in that area. Also, with the lid up, should I be able to turn the basket/drum freely by hand? I can not at this time, it seems to be locked up very tightly, I can turn it, but it has a lot of drag, leading me to think that is causing the motor to heat up. It is the orginal motor, not the current upgrade with the external capacitor and new wiring harness.
Any help is appreciated, I am a do-it-yourselfer, so I'm not afraid to tackle this and save some bucks.
Thanks,
Henry
