raterus
#1 Posted : Thursday, April 23, 2009 4:55:34 AM(UTC)
raterus
Hello,
I've diagnosed a problem I'm having with a leaky ice maker and it's with this part,
http://www.appliancepartspros.c...t_id=4009555&image=1
My only issue now is how to replace the plumbing attached to it. On the defective part, the tubes just go into this piece, with no clear way to get them out, nothing to screw.
Can someone tell me the proper way to disconnect the old hoses, and put them into this new part? Will I need any additional hardware before I order?
Thanks,
--Michael
woodchuckie
#2 Posted : Thursday, April 23, 2009 5:24:34 AM(UTC)
woodchuckie
You slide the blue ring in while you pull the tube out and put it in the new one the same way.
raterus
#3 Posted : Thursday, April 23, 2009 5:38:44 AM(UTC)
raterus
Hmm... So I actually push the blue ring in, with say a screw driver? I'm assuming that will open something up. Sorry for being so detailed, I just want to make sure I do this right and don't damage anything!
woodchuckie
#4 Posted : Thursday, April 23, 2009 11:24:11 AM(UTC)
woodchuckie
You should be able to move the ring with your fingers holding the tube in your hand.
raterus
#5 Posted : Thursday, April 23, 2009 11:43:04 AM(UTC)
raterus
Thanks for your help, I appreciate it!
