Larkin
#1 Posted : Wednesday, April 22, 2009 12:15:34 PM(UTC)
Larkin
Leak down Stand pipe....have replaced float and standpipe ...still leaks during wash and rinse cycles.
Drags1998
#2 Posted : Wednesday, April 22, 2009 1:53:15 PM(UTC)
Drags1998
Remove the float, and remove 1/8 in.(from the end of the float) at a time until it stops leaking.:)
Larkin
#3 Posted : Wednesday, April 22, 2009 2:47:50 PM(UTC)
Larkin
the end of the float is a slim rod with a stopper head on it.
Drags1998
#4 Posted : Wednesday, April 22, 2009 2:51:06 PM(UTC)
Drags1998
The SMALL END!!!!(or the BOTTOM):)
Larkin
#5 Posted : Wednesday, April 22, 2009 3:25:11 PM(UTC)
Larkin
the bottom of the float has a slim plastic rod with a stopper shaped end on it. The rod does not detach from the float. If I cut 1/8th of an inch of of the end, i will be cutting the stopper end off which will prevent it from going through the end of the float to the cutoff switch without hanging up on the shoulders of the guide.
Drags1998
#6 Posted : Wednesday, April 22, 2009 5:04:44 PM(UTC)
Drags1998
If you cut 1/8 off the float it will lower the water level about 1/2" in the tub, which will stop your leaking problem!!!
Larkin
#7 Posted : Wednesday, April 22, 2009 7:08:08 PM(UTC)
Larkin
Did not work.
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Dishwasher leak at float (Dishwasher Repair)
by warrenmott1 1/2/2018 12:37:31 PM(UTC)
Kemore Dishwasher Leak (Dishwasher Repair)
by Chevyman22360 7/19/2017 11:40:09 AM(UTC)
dishwasher leak at door (Dishwasher Repair)
by rpantel 4/26/2017 12:31:18 PM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
Dishwasher leaking from motor area (Dishwasher Repair)
by jay143 11/1/2016 12:20:29 PM(UTC)
Dishwasher Leaking (Dishwasher Repair)
by alanwoodbury 9/26/2016 10:47:47 AM(UTC)
whirlpool dishwasher leaking from door (Dishwasher Repair)
by pburd89 2/19/2016 1:36:17 PM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Kitchenaid dishwasher leaking (Dishwasher Repair)
by steve80124 9/21/2015 2:15:04 PM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
dishwasher leak under motor area (Dishwasher Repair)
by rheare 8/22/2015 11:52:33 AM(UTC)
dishwasher leak. What's this part? (Dishwasher Repair)
by pman6 7/2/2015 4:16:27 PM(UTC)
dishwasher leak when starting cycle. Drain pipe? (Dishwasher Repair)
by pman6 7/1/2015 12:16:44 PM(UTC)
