Larkin
#1 Posted : Wednesday, April 22, 2009 12:15:34 PM(UTC)
Larkin
Leak down Stand pipe....have replaced float and standpipe ...still leaks during wash and rinse cycles.
Drags1998
#2 Posted : Wednesday, April 22, 2009 1:53:15 PM(UTC)
Drags1998
Remove the float, and remove 1/8 in.(from the end of the float) at a time until it stops leaking.:)
Larkin
#3 Posted : Wednesday, April 22, 2009 2:47:50 PM(UTC)
Larkin
the end of the float is a slim rod with a stopper head on it.
Drags1998
#4 Posted : Wednesday, April 22, 2009 2:51:06 PM(UTC)
Drags1998
The SMALL END!!!!(or the BOTTOM):)
Larkin
#5 Posted : Wednesday, April 22, 2009 3:25:11 PM(UTC)
Larkin
the bottom of the float has a slim plastic rod with a stopper shaped end on it. The rod does not detach from the float. If I cut 1/8th of an inch of of the end, i will be cutting the stopper end off which will prevent it from going through the end of the float to the cutoff switch without hanging up on the shoulders of the guide.
Drags1998
#6 Posted : Wednesday, April 22, 2009 5:04:44 PM(UTC)
Drags1998
If you cut 1/8 off the float it will lower the water level about 1/2" in the tub, which will stop your leaking problem!!!
Larkin
#7 Posted : Wednesday, April 22, 2009 7:08:08 PM(UTC)
Larkin
Did not work.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 12/22/2022 5:12:45 PM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
Belarus Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
dishwasher leak varies (Dishwasher Repair)
by scottsasa 1/3/2021 4:23:28 AM(UTC)
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 12/11/2020 5:03:57 AM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Dishwasher leak at float (Dishwasher Repair)
by warrenmott1 1/2/2018 12:37:31 PM(UTC)
Kemore Dishwasher Leak (Dishwasher Repair)
by Chevyman22360 7/19/2017 11:40:09 AM(UTC)
