owenlaken
#1 Posted : Wednesday, April 22, 2009 12:03:24 PM(UTC)
owenlaken
Has been making a loud noise while washing but still worked....Today the green light under "clean" is flashing but it didn't wash and when I try to start it again it won't do anything? The green button under clean just continues to blink....
#2 Posted : Thursday, April 23, 2009 12:19:31 PM(UTC)
The Clean LED blinking 7 times means the control senses a fault in the temperature rise during the heating cycle.
The electronic control could be reset by initiating a service diagnostic cycle.
While the dishwasher is inactive press the Heated dry, Normal, Heated dry, Normal keys within 6 seconds.
If it happens again then the heating circuit should be diagnosed.
Regarding a loud noise I would recommend to check the pump chopper for a foreign objects. You can find the instructions in one of our previous posts: http://forum.appliancepartspros...hirlpool-dishwasher.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2400XTPT3 | AppliancePartsPros.com
Ex-SearsTech
#3 Posted : Tuesday, April 28, 2009 4:01:06 PM(UTC)
Ex-SearsTech
A clogged sump can actually trigger the clean light flashing.
