I followed the diagnostic process and it suggests that the door switch is faulty. I removed the switch. How can I test it to be sure it is the problem before I order replacement? The contacts on the switch work (continuity). The wax motor does not have continuity between the connectors on the motor. Is the motor open? Thanks.
Looking at the wiring diagram there should be continuity through the wax motor.
