Ned Lesh
#1 Posted : 13 years ago
Ned Lesh
I followed the diagnostic process and it suggests that the door switch is faulty. I removed the switch. How can I test it to be sure it is the problem before I order replacement? The contacts on the switch work (continuity). The wax motor does not have continuity between the connectors on the motor. Is the motor open?
Thanks.
sidfink43
#2 Posted : 13 years ago
sidfink43
Looking at the wiring diagram there should be continuity through the wax motor.
