My dishwasher makes a grinding noise and doesn't spray well. I took it apart and cleaned and inspected it. The only thing I can see is possiable play in the blades or maybe the end isn't seated in its grove properly. When I put it back together it will run good for a bit, then back to grinding noise and the pressure drops off. Any sugestions?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
