curtisr69
#1 Posted : Sunday, April 19, 2009 12:45:26 PM(UTC)
curtisr69
Is there any way to tell if the defrost timer is working properly on a refrigerator. I received a message that it could be the timer or it might be the fan not running. If the fan is not working should I just replace the motor and see if that fixes it? Does the condenser fan run all the time? Can the timer be bad and the defrost on all the time? All the help you can give is welcome.:confused:
woodchuckie
#2 Posted : Sunday, April 19, 2009 2:26:24 PM(UTC)
woodchuckie
Check timer, heater, and defrost thermostat. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
The fan should be running when the compressor is running except when it's in the defrost cycle or the door open.
