berkey
#1 Posted : Saturday, April 18, 2009 8:45:27 AM(UTC)
berkey
what should my voltage be to the icemaker? it has a 4 wire connector with white, black, brown and green. right now I am reading 57 volts to the white and black, and it does not seem to change when the optics or clear or blocked.
#2 Posted : Sunday, April 19, 2009 3:22:22 AM(UTC)
Need model # to help. If you can gain access to the front of the icemaker and it is a modular one, remove the cover and check the voltage to pins N and L, should be 115 volts, if not, your optics boards are bad. There should be a service sheet for the icemaker and optics under the kick panel.
Low voltage to ice maker (Refrigerator & Freezer Repair)
by ehorowitz 3/21/2018 12:56:38 PM(UTC)
