The Three Solenoids All Shift....the Cold Water Works Fine...when I Lift/lower The On/off Lever On The Ice Maker, I Get No Current To The Solenoid Switch For The Ice Maker.....what's Next? Ron Ferber
Originally Posted by: glassified The Three Solenoids All Shift....the Cold Water Works Fine...when I Lift/lower The On/off Lever On The Ice Maker, I Get No Current To The Solenoid Switch For The Ice Maker.....what's Next? Ron Ferber If you're getting current to the on/off lever then that switch isn't working. Just keep backing up till you have current to find the problem.
Thanks For The Help....i Removed The Water Line Going Into The Freezer In The Back Of The Unit And Blwe Thru It...not Frozen...then I Electrified The Ice Making Solenoid And It Ran Water.....so Everything Works But The Switch Is Not Sending The Message To Send Water......i Will Talk To ************** Guys Tomorrow......thanks For All Your Help And Quickness.
Ron
