glassified
#1 Posted : Sunday, April 19, 2009 11:55:26 AM(UTC)
glassified
The Three Solenoids All Shift....the Cold Water Works Fine...when I Lift/lower The On/off Lever On The Ice Maker, I Get No Current To The Solenoid Switch For The Ice Maker.....what's Next?
Ron Ferber
woodchuckie
#2 Posted : Sunday, April 19, 2009 2:37:40 PM(UTC)
woodchuckie
Ron Ferber
If you're getting current to the on/off lever then that switch isn't working. Just keep backing up till you have current to find the problem.
glassified
#3 Posted : Sunday, April 19, 2009 4:16:01 PM(UTC)
glassified
Thanks For The Help....i Removed The Water Line Going Into The Freezer In The Back Of The Unit And Blwe Thru It...not Frozen...then I Electrified The Ice Making Solenoid And It Ran Water.....so Everything Works But The Switch Is Not Sending The Message To Send Water......i Will Talk To ************** Guys Tomorrow......thanks For All Your Help And Quickness.
Ron
