Noticed freezer not cooling have thermometer in door45 degrees,back of freezer is 3/4 in of ice, advanced the defrost timer did nothing. I know it has heaters but part time work prevents buying something that I cant use. Is there a defrost t-stat and where is it. I am sort of handy Thanks
Originally Posted by: hairless15006 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Noticed freezer not cooling have thermometer in door45 degrees,back of freezer is 3/4 in of ice, advanced the defrost timer did nothing. I know it has heaters but part time work prevents buying something that I cant use. Is there a defrost t-stat and where is it. I am sort of handy Thanks check defrost timer, defrost heater, defrost thermostat Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Originally Posted by: hairless15006 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Noticed freezer not cooling have thermometer in door45 degrees,back of freezer is 3/4 in of ice, advanced the defrost timer did nothing. I know it has heaters but part time work prevents buying something that I cant use. Is there a defrost t-stat and where is it. I am sort of handy Thanks The heater comes with the thermostat, around $65.00. You have to take off the rear freezer panel to see if you are getting power to the heater when timer is in defrost.
thanks for info, part-time work is in way of looking at it, will let you know when I can look at it
