jm605
#1 Posted : Thursday, November 29, 2007 6:45:55 PM(UTC)
jm605
My oven gets either too hot or not hot enough. I don't know if its the sensor or the control panel but there seems to be some type of electrical problem. It preheats to the temperature and then either cools down or heats up too high so baking anything either takes hours or minutes. Any help at all would be appreciated. Thanks.
#2 Posted : Thursday, November 29, 2007 7:00:19 PM(UTC)
Most likely the problem with your oven is a bad control board but if it cools down after preheated, the bake burner could be bad too.
- The part number for the control board (black) AP3841165
- The part number for the control board (white) AP3841218
- The part number for the bake burner AP3598752
- Here are the break down diagrams for the Whirlpool range Model SF377PEGB5
