Originally Posted by: Rick Reeps  Is there a set of instructions for dis assembling the dryer? Hey Rick, too many questions and not enough answers. HUH? Let me help you out. Unplug the dryer, and pull the lint screan out, and right there you will see 2 phillip head screws. Remove them. Now, we need to pop up the top. Get a putty knife and slide it under the top, about 3 inches from each end, and you will hit a clip that will release the top. Once you have released the top, push it all the way back and rest it on the back wall. Now if you want to take the front off, look inside the front, up top on the right and left side, and you will see a 5/16s screw on each side. Remove them, and then grab the left side and pull up quick and hard, and the bottom will release from the clip on that side. Then do the same on the other side. Once both side are released, remove the wires from the door switch, and now the whole front is off. If you want to take the drum out, lay down on your stomach, and push the the pully over to release the tention on the belt, and take the belt off. Look at it before you do so, so you will know how to put it on. There you go my good man. Tom ApplianceEducator.com
