Compressor quit running everything thawed... bypassed motherboard by shorting line to compressor at motherboard connector.. compressor ran fine. this means capacitor is good I guess. What can I test or bypass to confirm motherboard is good or not.. Is there a thermostat or thermistor or something that tells the motherboard to turn on relay that runs compressor.?? I have no diagram to work from.. thanks redster55 yuma
Nobody gets a diagram, except authorized GE personnel. Highly likely to be a mother board problem.
Well...pulled motherboard... line in pin to compressor relay burned..desoldered and removed relay..cleaned pin and resoldered to m/b and she is running but for how long who knows....clamp on ammeter shows compressor pulling normal current... Probably have to buy a motherboard before its over...thank goodness for the reefer in the fifth wheel
The schematic should be behind the control panel.
