redster55
#1 Posted : Monday, September 19, 2011 1:24:58 PM(UTC)
redster55
Compressor quit running everything thawed... bypassed motherboard by shorting line to compressor at motherboard connector.. compressor ran fine.
this means capacitor is good I guess. What can I test or bypass to confirm motherboard is good or not.. Is there a thermostat or thermistor or something that tells the motherboard to turn on relay that runs compressor.??
I have no diagram to work from..
thanks
redster55
yuma
magician59
#2 Posted : Monday, September 19, 2011 1:40:17 PM(UTC)
magician59
Nobody gets a diagram, except authorized GE personnel. Highly likely to be a mother board problem.
redster55
#3 Posted : Monday, September 19, 2011 5:17:43 PM(UTC)
redster55
Well...pulled motherboard... line in pin to compressor relay burned..desoldered and removed relay..cleaned pin and resoldered to m/b and she is running but for how long who knows....clamp on ammeter shows compressor pulling normal current...
Probably have to buy a motherboard before its over...thank goodness for the reefer in the fifth wheel
#4 Posted : Tuesday, September 20, 2011 1:34:53 AM(UTC)
The schematic should be behind the control panel.
compressor quit (Refrigerator & Freezer Repair)
by tigereye69692000 6/17/2013 12:36:41 PM(UTC)
replaced condesor fan and both it and compressor quit (Refrigerator & Freezer Repair)
by pflorian 1/19/2012 10:03:43 PM(UTC)
