Tim56
#1 Posted : Monday, September 19, 2011 8:44:01 AM(UTC)
Tim56
This is going to be a long post. I have read many of the other posts and have gone through the tests suggested. He are the specs: GE Hyrowave w/infusor. Model WHRE5550K2WW manuf 01/2009 and purchased 1/2010. Motor #175D5106G057. PROBLEM: When filling it starts to fill then after 5-10 seconds it starts to spin fast and still fill. LED lights on panel start with fill, then to wash then back to fill. Spinning eventually stops and sometimes it goes no further. Other times it continues on with the cycles and other times it gets to the rinse, goes through that but then back to wash (according to the LED lights).This doesn't stop, as though it's stuck in a loop. All this time the machine is making the normal clunks etc that the shifter is supposed to make. Both the agitator and drum move at the same time..which makes me believe the shifter coil is bad. Basically that's it. It doesn't appear to do all these things on all cycles though-maybe because different cycles have different modes it goes through. Now the Tests: MOTOR LED-green-blinks normal for both washer off (1 sec continual) and washer on (.5 sec continual). No error codes. In SERVICE MODE: All positions are ok. No error codes-(positions 2-4). Positions 5-11, functions are all ok. Pressure switch ok both full and empty. LID SWITCH: Has continuity when closed, none when open. RESETTING: Tried, but no go. MODE SHIFTER COIL: C7 reads 67 Ohms not 98. FUSE: OK-neutral tab to white/red wire-got continuity. C4 CONNECTOR: (blue,far right). Pin 5 to 3 -12 VDC. Pin 5 to 4 -12 VDC. C CONNECTOR: (white, far left). White/red wire to red/black-120V. Also the large pulley does turn free. AND I already replaced the control board suggested by another forum. Can the motor still be bad if the LED is showing normal or is it because the shifter coil is only reading 67 ohms, not 98? Is that a motor problem...not getting enough juice to the coil? Please don't tell me both or the sledge hammer is coming out !
brian24
#2 Posted : Sunday, October 6, 2013 8:43:11 PM(UTC)
brian24
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
brian24
#3 Posted : Sunday, October 6, 2013 8:47:45 PM(UTC)
brian24
Did you ever find a solution to your GE washer filling and spinning at the same time,I also have these issues seems like the cycles are not right changed circuit board did not solve issue.Thanks
brian24
#4 Posted : Sunday, October 6, 2013 8:48:39 PM(UTC)
brian24
:rolleyes: :rolleyes: Did you ever find a solution to your GE washer filling and spinning at the same time,I also have these issues seems like the cycles are not right changed circuit board did not solve issue.Thanks
lola1234
#5 Posted : Monday, December 7, 2015 5:40:01 PM(UTC)
lola1234
Was the problem ever resolved? Washer spins during the fill cycle and final spin is not complete. I have replaced control board assembly to no avail...
Guest
#6 Posted : Wednesday, February 21, 2024 3:37:16 PM(UTC)
Guest
Rank: Guest
United States
Guest
#7 Posted : Wednesday, February 21, 2024 3:40:35 PM(UTC)
Guest
Rank: Guest
United States
