KMan105
#1 Posted : Wednesday, November 28, 2007 3:45:20 PM(UTC)
KMan105
I have a GE Nautilus dishwasher that will not drain completely. It sounds as though the pump is trying to run. I have yet to check the hose to see if it is clogged. Please let me know if there is anything else that I need to look at as well. there is nothing in the owners manual to help. Thanks.
#2 Posted : Wednesday, November 28, 2007 8:13:21 PM(UTC)
Remove the bottom panel and check if the pump is working.
If the motor is not moving but makes a humming noise then replace the pump and motor assembly.
If there is nothing wrong with the motor, check the drain line.
I would start to check the drain line from the air gap on top of the sink (if there is one). Remove the cover and the top piece and check for clog.
Disconnect the drain hose from the air gap, put the end of the hose in a bucket and start the drain. Look for any foreign objects coming out.
Remove the lower dish rack, then remove the filter frame on the back (#543 on the body break down diagram) and unscrew the piston & nut (#564 on the same break down diagram). Replace if it's worn out.
If it did not help, remove all water from the dishwasher. Remove the dishwasher from the cabinet. Disconnect the drain hose from the check valve (#560 on the body break down diagram).
Check the drain hose for any clog.
Replace the check valve assembly.
- The part number for the pump & motor assembly AP2616850
- The part number for the piston & nut assembly AP2617344
- The part number for the check valve assembly AP2039866
- Here are the break down diagrams for the GE dishwasher Model GSD3400G00CC
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
