Oven door glass broke and we have received replacement glass with no directions. How do we install?
I am not a repair man but have taken out my glass before.When you open the door you should see screws at each corner. Take them out. The door is made in two pieces. The front of the door and the back come apart. Carefully separate them. You should be able to remove the glass.
