water comes in very slow from cold water hose. I remove hose from washer and clean screen filter. I replace hose and water comes in good for a awhile. Then, it slows down again. What should I do and how do I do it?
Robert T. Smith
you may have more screens ,check to see if there screens in the hose near the taps an at the washer. Then with the hose off, check the screen in the mixing valve on the washer if dirty clean and replace. don,t remove this screen.
I haven't received any info on how to fix my problem that I posted or if you did answer, I don't know how to find it.
