I have a old gas Sears boiler that is 40 to 50 years old. The Thermostat Control Relay needs to be replaced. I called Sears and the part# 387.92551 has been discontinued. Is there another thermostat control relay made by a different manufactor that would work? Thanks John
Originally Posted by: kybigblue ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a old gas Sears boiler that is 40 to 50 years old. The Thermostat Control Relay needs to be replaced. I called Sears and the part# 387.92551 has been discontinued. Is there another thermostat control relay made by a different manufactor that would work?
Thanks John A thermostat control relay? Either a fan relay or control relay. Assuming you are correct about being a "Boiler" eliminates fan relay. So any relay with a 24volt coil will work. A relay is just a switch. :)
From Sears : part: 387.92551 Substitution: 8E42A-1 Category:Plumbing and Heating $98.99 In stock
Joined: 11/5/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Ohio
Can anyone still see this post?? I have the same boiler and it is out...it's so old that even the replacement suggested..I can't find..Please help?
