kybigblue
#1 Posted : 16 years ago
kybigblue
I have a old gas Sears boiler that is 40 to 50 years old. The Thermostat Control Relay needs to be replaced. I called Sears and the part# 387.92551 has been discontinued. Is there another thermostat control relay made by a different manufactor that would work?
John
icehouse
#2 Posted : 16 years ago
icehouse
John
A thermostat control relay? Either a fan relay or control relay. Assuming you are correct about being a "Boiler" eliminates fan relay. So any relay with a 24volt coil will work. A relay is just a switch. :)
icehouse
#3 Posted : 16 years ago
icehouse
From Sears :
part: 387.92551
Substitution: 8E42A-1
Category:Plumbing and Heating
$98.99 In stock
icehouse
#4 Posted : 16 years ago
icehouse
sarina1111s
#5 Posted : 4 years ago
sarina1111s
United States
Can anyone still see this post?? I have the same boiler and it is out...it's so old that even the replacement suggested..I can't find..Please help?
