HURICANESRUL
#1 Posted : Friday, September 16, 2011 10:44:32 AM(UTC)
HURICANESRUL
dishwash motor runs....no water is coming into the washer. water is coming into line to dish washer?? it's new....bought discounted because it had a scratch on the front.
Joe / APP Team
#2 Posted : Friday, September 16, 2011 11:09:50 AM(UTC)
Joe / APP Team
Remove the kickplate and check the wires to the fill valve and float switch Part number: AP4429566
Part number: AP4502060
and make sure none of the wires have been dislodged or broken/damaged, and the float stem is activating the switch when the tub is empty. Then replace the fill valve if all checks are OK.
Good Luck,
HURICANESRUL
#3 Posted : Friday, September 16, 2011 2:09:46 PM(UTC)
HURICANESRUL
what is the float valve ?? i don't hear anything clicking when it starts...just the motor ?? all the wires look good .
HURICANESRUL
#4 Posted : Friday, September 16, 2011 2:11:43 PM(UTC)
HURICANESRUL
wht is the fill valve ?? how do i check it ??
Joe / APP Team
#5 Posted : Monday, September 19, 2011 5:27:48 AM(UTC)
Joe / APP Team
Your Float and switch assembly are located in the left front corner, on the bottom of the tub interior, the round object in the coner. I f you slowly and carefully lift and drop the float, you should hear a slight clicking noise, when the switch is activated(down) and deactivated(up).
Your fill valve is located in the same area, but you will need to remove the lower panels from the front of the dishwasher to access it, There will be a hartness with two wires that plug onto the terminals of the fill valve, And two wires that attach to the float assembly switch directly above the fill valve.
You'll need to check the wires and the switch for proper connections, and operation.
GE Profile will not spray water (Dishwasher Repair)
by jimmys3000gt 8/2/2013 1:28:36 PM(UTC)
Dish washer fills with water but will not clean the dishes, it will not spray the dis (Dishwasher Repair)
by gmcjohn 11/27/2012 5:08:54 AM(UTC)
Whirlpool Dishwasher intermittently will not spray (Microwave Repair)
by mgruebe3 5/29/2011 5:43:00 AM(UTC)
Will not spray water (Dishwasher Repair)
by iwellman 10/31/2010 1:24:39 PM(UTC)
Dishwasher Hums Loud and Water Will Not Spray (Dishwasher Repair)
by erikazemi 4/5/2010 9:15:49 AM(UTC)
Dishwasher will not spray water. (Dishwasher Repair)
by wilhitej 7/31/2009 11:14:16 AM(UTC)
dishwasher will not spray or pump off water (Dishwasher Repair)
by skb 6/2/2009 3:06:57 PM(UTC)
water will not spray dishes. (Dishwasher Repair)
by Ranger6 12/16/2008 3:18:40 PM(UTC)
