Markie21
#1 Posted : 16 years ago
Markie21
Just replaced the motherboard again, and get the same read out on the freezer temp: "PEO" and fridge temp: "000".
I thought the original replacement was defective, but the second one does the same. When I put back in the old one, the fridge/freezer works, but not the ice maker/water dispenser, which does work with the new control board.
#2 Posted : 16 years ago
Did you program the new control board as described in the installation instructions and in the Service manual linked in the previous thread (http://forum.appliancepartspros...g-refrig-error-code.html)?
Markie21
#3 Posted : 16 years ago
Markie21
Yes Gene. Thanks for sending the manual. Helps to read the directions! It works great.
Thanks again,
Mark
#4 Posted : 16 years ago
You are welcome.
Maytag refrig error code (Refrigerator & Freezer Repair)
by Markie21 16 years ago
