Just replaced the motherboard again, and get the same read out on the freezer temp: "PEO" and fridge temp: "000".
I thought the original replacement was defective, but the second one does the same. When I put back in the old one, the fridge/freezer works, but not the ice maker/water dispenser, which does work with the new control board.
Yes Gene. Thanks for sending the manual. Helps to read the directions! It works great. Thanks again, Mark
