Ice maker Model IM6.
What I have done: Changed Water Supply valve-No effect. Ice maker inlet tube is clear – no ice blocking water flow. Freezer temperature -10 F Ice maker light is steady green-not flashing Feeler arm moves easily back and forth-no apparent problem with spring mechanism. Freezer door light switch OK. (Water stops flowing to dispenser when door is opened) Ice maker jump started (turned ice maker off for 30 seconds; Pushed feeler arm back and released 3 times in 15 seconds. No water flow to icemaker.
Any ideas? I am about to give up the fight. Thanks.
