ffizzino
#1 Posted : Tuesday, April 14, 2009 5:22:48 PM(UTC)
ffizzino
Ice maker Model IM6.
What I have done:
Changed Water Supply valve-No effect.
Ice maker inlet tube is clear – no ice blocking water flow.
Freezer temperature -10 F
Ice maker light is steady green-not flashing
Feeler arm moves easily back and forth-no apparent problem with spring mechanism.
Freezer door light switch OK. (Water stops flowing to dispenser when door is opened)
Ice maker jump started (turned ice maker off for 30 seconds; Pushed feeler arm back and released 3 times in 15 seconds. No water flow to icemaker.
Any ideas? I am about to give up the fight. Thanks.
#2 Posted : Wednesday, April 15, 2009 2:07:44 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...ice-maker.html#post79236
