poettcker
#1 Posted : Monday, April 13, 2009 3:23:22 PM(UTC)
poettcker
The bake element quit working. While removing it there was a shock(the knob was not turned completely off) and now the broiler element will not heat, but all the fans and lights work(no flipped breaker). Is there a reset button for the elements? I don't want to buy a new bake element and still have an oven that will not work.
#2 Posted : Tuesday, April 14, 2009 7:36:32 PM(UTC)
It's hard to say if there is any protector without the wiring diagram. This model is very old and there is no diagrams available on-line. If you do have one and can post it then it might help.
Jenn Air Double Oven Malfunctioning (Oven Repair (including Ranges and Cooktops))
by Guest 12/27/2021 3:48:46 PM(UTC)
amana range/oven malfunction (Oven Repair (including Ranges and Cooktops))
by gadms 11/14/2013 11:14:22 AM(UTC)
dacor wall oven malfunction (Oven Repair (including Ranges and Cooktops))
by cjargo72 4/11/2012 8:30:49 PM(UTC)
KitchenAid Oven Malfunction Causes Food Fire (Oven Repair (including Ranges and Cooktops))
by dogma327 9/21/2010 8:39:07 AM(UTC)
GE Oven Malfunctioning (Oven Repair (including Ranges and Cooktops))
by Tsmithcma 7/4/2010 7:43:11 AM(UTC)
