The bake element quit working. While removing it there was a shock(the knob was not turned completely off) and now the broiler element will not heat, but all the fans and lights work(no flipped breaker). Is there a reset button for the elements? I don't want to buy a new bake element and still have an oven that will not work.
It's hard to say if there is any protector without the wiring diagram. This model is very old and there is no diagrams available on-line. If you do have one and can post it then it might help.
