jfrauch
#1 Posted : Friday, April 10, 2009 3:29:47 PM(UTC)
jfrauch
Our oven is not heating correctly, and hasn't been for awhile. It's become more obvious lately so we finally bought a thermometer to hang off the oven rack.
For example: oven temp set at 450, preheat will beep and turn off when thermometer reads 315. It sometimes will heat a bit further but never reaches the set point.
We replaced the sensor about 6 weeks ago (it was a $20 part so we figured why not), but it did not help.
I did go into the controls and calibrate the oven up, by as much as 20 points initially. Eventually we set the calibration up the full 35 points.
It does seem to be getting worse. :(
I can tell you both elements work, so can I assume it's the controller? My understanding would be that an element would either work or not work, seeing how it's resistive.
I can change the controller myself, as I am quite technically adept, but have no idea how to troubleshoot it if that were possible. Besides, $150 bucks is cheaper than a new oven :)
That being said, we've never been happy with the cooktop elements. They take FOREVER to boil water and heat anything larger than a medium pot.
Your thoughts are greatly appreciated!
John
#2 Posted : Saturday, April 11, 2009 2:10:57 AM(UTC)
Replacement parts for FRG FEF366CCA | AppliancePartsPros.com
Here is the wiring and the tech sheet
ftp://ftp.electrolux-na.com/Pr...pringfield/316255173.pdf
ftp://ftp.electrolux-na.com/Pr...ingfield/316218506en.pdf
Not necessarily. The sensor increases resistance with temperature, lets say you have a dirty connector on the board and it adds 100 ohms of resistance to the circuit, Then your oven will be off by 50 degrees, as it thinks it is hotter than it actually is.
Since both stove top and oven have the same problem (low heat), I would check the power at the plug with the unit off and then on. You should have 240 volts and it should not drop much if at all when the oven is on.
Be careful 240 volts is lethal!!!
