pghhoover
#1 Posted : Thursday, April 9, 2009 4:39:42 PM(UTC)
pghhoover
I installed new igniter and still wont glow could it be igniter switch?
#2 Posted : Friday, April 10, 2009 8:30:18 PM(UTC)
Unplug the igniter and check for 120VAC to the igniter while the control calls for heat. Post the results.
pghhoover
#3 Posted : Saturday, April 11, 2009 6:06:03 AM(UTC)
pghhoover
no power coming out of wiring harness to ignitor
#4 Posted : Saturday, April 11, 2009 7:23:52 PM(UTC)
I'm assuming we are talking about the Bake igniter. There is a dual gas safety valve for both Bake and Broil. Locate the two terminals on this valve for the Bake, remove the wires from it and check for continuity between them. If there is no continuity then the gas safety valve has to be replaced.
- The part number for the gas safety valve is AP4098213
Here are the break down diagrams and Replacement parts for MAGIC CHEF CGR3760ADW | AppliancePartsPros.com
deutsr01
#5 Posted : Tuesday, April 14, 2009 5:32:09 PM(UTC)
deutsr01
Hi, so the saftey will allow gas to flow for Broiler, but not for baking?
#6 Posted : Tuesday, April 14, 2009 8:19:01 PM(UTC)
This is a dual valve and Bake and Broil sections are separated.
Is it the igniter switches or spark module? (Oven Repair (including Ranges and Cooktops))
by JRichied 4/26/2015 5:12:32 PM(UTC)
How to remove D clips in front of igniter switch (Oven Repair (including Ranges and Cooktops))
by poppy123 9/1/2013 7:14:55 AM(UTC)
Alternate Magic Chef Igniter Switch (Oven Repair (including Ranges and Cooktops))
by ejlebeau 7/13/2011 4:20:57 PM(UTC)
Wire Polarity For GE Igniter Switch (Oven Repair (including Ranges and Cooktops))
by quark 3/25/2011 11:06:20 AM(UTC)
One Thermador igniter switch malfunction (Oven Repair (including Ranges and Cooktops))
by ronrosenfeld 10/5/2010 6:31:47 PM(UTC)
Igniter switch (Oven Repair (including Ranges and Cooktops))
by danielr 11/7/2009 9:28:52 AM(UTC)
Replacement igniter switch is diffrent from original part (Oven Repair (including Ranges and Cooktops))
by danielr 11/6/2009 6:54:54 AM(UTC)
