freezer works but refrigerator is warm the fan in the freezer works .but sometimes the freezer and refrigerator is warm .the thermostat seems to work and the fan on the compressor works so where do i go from here
Check the evaporator coils in the back of the freezer behind the back panel. Are they blocked up with ice blocking air circulation in the freezer and to the fridge? If so, defrost problem.
their is no ice on the back coils and the fan does seem to work in the back of the freezer.where do i go from here
Were the coils in the freezer really cold? The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
When the compressor is running, is the fan near the compressor running also?
Are the condenser coils near the compressor warm?
