ejarrell@insight.rr.com
#1 Posted : Wednesday, April 8, 2009 1:25:47 PM(UTC)
Clothes have to be ran through the dryer several times to get completely dry. The heating element comes on (on part briter than the other) and cycles off after a minute, but the clothes take several times through a whole cycle to dry. Not sure if I should replace the element or I have one or more bad thermostats. Ed
BIGbob09
#2 Posted : Wednesday, April 8, 2009 2:00:13 PM(UTC)
BIGbob09
Had the same problem replaced the heating element becuase one of the elements were broken. ALso check your vent that exits the house it may be clogged, perfect time for bird nests......
#3 Posted : Wednesday, April 8, 2009 3:16:12 PM(UTC)
Replacement parts for WHIRLPOOL EED4300TQ0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Yes sounds like the heating element is grounded, either is has broken or sagged and is touching the case. Pull it and take a look OR if you have a meter pull both wires and measure between the heater's connectors should he around 8 ohms. Then measure from each connector to the case, should be infinite (open).
